Configurations & if Statements
Nath_McC
Member Posts: 135 PRO
Hi,
I am coming from Solidworks and i would have normally put a simple if statement in the dimensions to get the desired result but that is not the case in onshape.
I have a model of a pin and a hole. Currently the pin has a variable of #PinD and basically I want to incorporate the following if statement for the hole
If ( #PinD * 1.2 > #PinD + 3 , #PinD * 1.2, #PinD + 3 )
Basically the hole to be which ever size is grated, #PinD * 1.2 or #PinD + 3
What is the best way to add this into the model?
TimRice
Member, Moderator, Onshape Employees Posts: 315
Our numeric inputs are actually quite flexible. This is possible using a ternary operator, as seen in the example below:
This applies to any numeric input in our product (both part studios and assemblies).
Onshape, Inc.6 -
RyanWiebe
Member Posts: 8 ✭✭
Is it possible for the value to read: ((#check>2*in) ? 3 : #check) in ?TimRice said:Our numeric inputs are actually quite flexible. This is possible using a ternary operator, as seen in the example below:
This applies to any numeric input in our product (both part studios and assemblies).0
Onshape, Inc.
