Kirimoto Newbie
scott_caskey
Posts: 55 PRO
Can someone tell me how you associate a specific cut with a tool? When I select all the tools I need for the operation, then animate it, all It animates is one tool. It completely ignores the other tools selected. I have a simple shape outlined with a mill then a hole in the center that I selected a drill bit for. It ignores the drill completely. the order of the tool use seems to have no effect either. Also where do you define a tool offset because it is running my mill right down the center of the outline.
@scott_caskey I'm thinking you might be on the wrong forum? This is Onshape not fusion.0
KiriMoto is integrated with Onshape:shawn_crocker said:@scott_caskey I'm thinking you might be on the wrong forum? This is Onshape not fusion.
https://appstore.onshape.com/apps/CAM?sort=featured
Oh Haha. Didn't release what was in your header.0
