Computer specifications
meritxell_costa
Member Posts: 5 PRO
Hello! My compnay is going to change my computer as I hava some problems when I work with several programs. For example, when I'm desining with OnShape, and I do a ciruclar pattern, with a lot of repetitions (200 fe), my browser spends a long time thinkking. Does OnShape has any specefications regarding the computer to use? Could you give me some tips that would improve my use of OnShape?
Thank you
Thank you
NeilCooke
Moderator, Onshape Employees Posts: 5,987
Hi @meritxell_costa - your computer spec will not make much difference to the speed it takes Onshape to compute a pattern as all that processing is done in the cloud. The only consideration is the amount of graphics you have on screen. If you are working on large assemblies, you will need a better graphics card and more RAM for the browser to be able to store the data in memory. You can use the comparative figures displayed at https://cad.onshape.com/check to see how good your graphics card is. This will make large assemblies rotate faster on screen, and more RAM will enable you to have more Onshape windows open at a time.
If your patterns are slow, maybe we can suggest alternative ways to model that will speed it up, but changing your computer is not one of them. Hope this helps.Senior Director, Technical Services, EMEA1 -
MichaelPascoe
Member Posts: 2,814 PRO
In general, your computer needs to have similar specs to a gaming pc because Onshape works kind of like games do. Here is the Onshape benchmark test, in my opinion, if the computer is not maxing this out, it is not a good computer for Onshape: https://cad.onshape.com/check
Using Windows, I was running:
Processor: Intel i7
Graphics card: gtx 1070 Super
RAM: 16g
This was good for most applications, however with larger assemblies and part studios, it was slow.
My current set up is much faster when loading larger part studios and assemblies, but also more expensive:
Processor: Ryzen 9 5900HX
Graphics card: RTX 3080 16GB
RAM: 32g
If you prefer Apple, here is a forum post that may help: https://forum.onshape.com/discussion/comment/66045#Comment_1
RENDERCAD
________________________________________________________________________1
Thank you very much
Processor: Intel i7
RAM: 16g
RAM: 32g
RENDERCAD
