After slicing in kiri-moto cnc dose not cut what is drawn.
silverardo52
Posts: 2 ✭✭
I drew a "D" shape handle 15mm all round sliced it in kirimoto going by the grid in kirimoto the job was all even .sliced it and preview it all looked good,exported to cnc and cut it but the x axis is ok but the y axis the part reduced to 6mm. I cant seem to find a setting to correct this.Can any won help?
All sorted re calibrated y axis in Mach3 settings, some how setting had changed0
Can you tell me how I tell Kirimoto which tool to use for which operation? I import a part then configure my tools but how do you tell it which tool to use for which cut?0
