revolve up to (flat) surface
mko_sc
Member Posts: 27 PRO
I have a closed profile and an axis leaning against a plane
I can revolutionize this closed profile up to a plane (which clearly intersects) and have qCapEntity
I wanted to avoid doing a full revolution, cut it and then select the resulting section.
Thanks
If you know the x vector along your sketch plane (vector1) and the x vector along the flat surface (vector2), you should be able to set the angle between the two as your total revolution angle:
angle = angleBetween(vector1, vector2); opRevolve(context, id + "revolve2", { "entities" : Sketch, "axis" : revAxis, "angleForward" : angle });
1 -
Thanks a lot #Kira_Leehowever I changed my approach and made an opBoolean fact
opRevolve(context, id + "revolve1", { "entities" : widget.faccia, "axis" : line(vector(0, 0, 0) * mm, vector(0, 0, -1)), "angleForward" : 170 * degree }); opExtrude(context, id + "extrude1", { "entities" : widget.entities, "direction" : evOwnerSketchPlane(context, { "entity" : widget.entities }).normal, "endBound" : BoundingType.BLIND, "endDepth" : 50 * mm }); var tools = qUnion([qCreatedBy(id + "extrude1", EntityType.BODY), qCreatedBy(id + "revolve1", EntityType.BODY)]); opBoolean(context, id + "boolean1", { "tools" : tools, "operationType" : BooleanOperationType.INTERSECTION, "allowSheets" : true }); debug(context, qCreatedBy(id + "boolean1"), DebugColor.RED);0 -
I'll test your example anywayThanks again0
