Sinus curve
amir_livne
Member Posts: 76 EDU
Hi
I'm trying to create a sinus curve using parametric curve script
Unfortunately it doesn't work
I'll appreciate if someone can help me
Thanks
Thanks
You can study the examples in the Parametric Curve document if you want more interesting curves: https://cad.onshape.com/documents/578ff8b3e4b0e65410fcfda3/v/9e1cf9e0369f819849e1e2fd/e/46b903b8bff0b36927baa2a6
Also, the FeatureScript console is useful for debugging feature regeneration failures.
