How to create drawings of standard content?
jack_aiello
Member Posts: 12 EDU
How do I create separate drawings of the standard content that can be added to assembly drawings?
https://cad.onshape.com/documents/07fe033cb975992fd16a8d89/w/8bdb1e2c9ef6200f1c23fe43/e/2f68a1d586bd65692b350d0d?renderMode=0&uiState=61d14630ab37cf7a81fcab22
@jack_aiello You can right click on any item in the assembly and export it as parasolid/step and then re-import into a new part-studio and do a drawing of that.
Alternately you can also just create a display state on the assembly showing just a single item of standard content and insert the assembly into a drawing and choose that display state.
I did an example of the latter:
https://cad.onshape.com/documents/5e9265f2aa3ccd48e014e3e9/w/47f86e09233261907a73a580/e/a410cb278bfecced97a031aa
