Sheet Metal flange with chamfer?
KyleDarnell
Member Posts: 10 ✭✭
I am trying to make a sheet metal part where there is a flange over another flange, and there is a chamfer. (I need to keep the bend relief the same) Here is the link to the document. "https://cad.onshape.com/documents/c52ff5bc0241164ba795ca18/w/4ab86817697433a36ca10fe9/e/1ee46ac2f48c42550c4009db?renderMode=0&uiState=61f9469cd4fe6a11461c08a1" The part studio called "ORIGINAL" is how we previously created it but, to avoid long regen times we had to make the changes before the sheet metal conversion. In the "OPTIMIZED" part studio is how I found a work around to create what I have mentioned at the start without making any changes to the part after the sheet metal conversion. Is there any other way to get the same result without having to cut into the part 2 times just so I can get a chamfer?
Can you still move the rollback bar with the link that I have attached? If not, how can I make it so you can and not change the official document.
(update: just fixed the link)
Yes we can still move the roll back bar. Check this document if this is still a problem for you.
https://cad.onshape.com/documents/00e9dbaef39d55a179c7bd83/w/d55e1b82a8005d616a4ec72e/e/cb37fbfd64be58a0b9d23e5d
I thing the problem is still there. Or fillet on 45 degrees is not possible
