Sheet Metal flange with chamfer?
KyleDarnell
KyleDarnell Member Posts: 10 ✭✭
I am trying to make a sheet metal part where there is a flange over another flange, and there is a chamfer. (I need to keep the bend relief the same) Here is the link to the document. "https://cad.onshape.com/documents/c52ff5bc0241164ba795ca18/w/4ab86817697433a36ca10fe9/e/1ee46ac2f48c42550c4009db?renderMode=0&uiState=61f9469cd4fe6a11461c08a1" The part studio called "ORIGINAL" is how we previously created it but, to avoid long regen times we had to make the changes before the sheet metal conversion. In the "OPTIMIZED" part studio is how I found a work around to create what I have mentioned at the start without making any changes to the part after the sheet metal conversion. Is there any other way to get the same result without having to cut into the part 2 times just so I can get a chamfer?
