how to insert an image into a drawing
Andrew_Michell
Member Posts: 7 PRO
I am trying to put an image in a drawing template.
I am following "inserting images" in these instructions: Best Practices for Creating Onshape Drawing Templates - Onshape Learning Center
After selecting the image, I drag from a point to insert it, but nothing happens.
What am I doing wrong?
A moment ago I was not even able to move elements of the drawing to the title block, so I thought I had really screwed something up. But now I am able to do that, and I am also able to place an image in it. So everything is working. But I am absolutely new to Onshape - is this kind of delayed reaction typical?0
thanks Michael1
Anytime @Andrew_Michell!
Looks like you have already found the learning center. A tip I wish I knew starting Onshape: Complete each of the Learning Pathways, I have learned so much from them.
▚▞▚▞▚▞▚▞▚0
