how to insert an image into a drawing
I am trying to put an image in a drawing template.
I am following "inserting images" in these instructions: Best Practices for Creating Onshape Drawing Templates - Onshape Learning Center
After selecting the image, I drag from a point to insert it, but nothing happens.
What am I doing wrong?
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,967 PRO
    edited March 2022 Answer ✓
    Sketches, part studios, and assembly studios are lightning fast. Drawing sheets can sometimes be sluggish, this is typical.
  • MichaelPascoe
    It sounds like you are following the correct steps. Can you share a link to a document with a drawing from your template?
  • Andrew_Michell
    Andrew_Michell Member Posts: 7 PRO
    A moment ago I was not even able to move elements of the drawing to the title block, so I thought I had really screwed something up. But now I am able to do that, and I am also able to place an image in it. So everything is working. But I am absolutely new to Onshape - is this kind of delayed reaction typical?
  • MichaelPascoe
  • Andrew_Michell
    thanks Michael
  • MichaelPascoe
    Anytime @Andrew_Michell!
    Looks like you have already found the learning center. A tip I wish I knew starting Onshape: Complete each of the Learning Pathways, I have learned so much from them.
