Searching a sketch for name
angelo_scozzarella
Member Posts: 58 EDU
I can’t find a search option for finding sketch names
If I understand you correctly, you should be able to search in the feature tree search bar.
If you're looking to filter for all sketches, you can search that way too, using ":type sketch" in the search bar.
A few other forum posts have examples. Here's one: https://forum.onshape.com/discussion/1213/tree-management-strategies-tagging-naming
And here's a handy checklist to run through when you've got a question: https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest1 -
Thank you and sorry for disturbing. Is it available in ios app too?1
Will be possible to have searching in ios version?0
