Not able to export dxf into Inkscape correctly
marc_wheeler
Member Posts: 4 EDU
I am trying to export a sketch into Inkscape as a dxf so I can laser cut on a Glowforge. I have done this many times. This design has a large ellipse and other sketch elements connected to this ellipse. Everything is in mm. When I export the sketch, I get the main ellipse about 6 times bigger than it should be and angled. The rest of the sketch elements are coming over OK, but the ellipse does not. I imported a rectangle from the same workspace and in the same file, and it came over fine. Any ideas why an ellipse would suddenly give me a problem.
You can try export splines as polyline's, or even a different version of DXF0
Thanks Dirk, but I tried this and still no luck. Here is a video of what I am doing if anyone has time to see.0
I had a look at your video and you are using release 14 DXF, have you tried an other version like 2004 or something.0
