How can you assign Part dimensions used in an assembly to a variable ?
I can use a part in an assembly that can have a different lengths.
I would like to measure the length , feature script possibly?, assign it to a variable which can then be used to
generate a resized sketch or possibly generate a new set of 8020 parts using the 8020 feature script.
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,020 image
    @hugh_wallace Based on your workflow, you want to create a variable that is globally accessible across the document, perhaps multiple documents? Global variables?
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • svenolov_nystrom
    svenolov_nystrom OS Professional Posts: 88 PRO
    A global variable would help me a lot in my current project!
