I am trying to create an epitrocoid, what could I be doing wrong?
elias_s617
Member Posts: 6 ✭
I am attempting to make an epitrochoid with the parametric curve feature script (linked below)
https://cad.onshape.com/documents/578ff8b3e4b0e65410fcfda3/v/9e1cf9e0369f819849e1e2fd/e/0c17de6a800d4aed83de417f
I have tried a few times. Everything seems to look good until I press the checkmark. The curve doesn't show up and the feature script says "Parametric curve 1 did not regenerate properly: Error regenerating." (photo below). I was wondering if anybody would have any idea what it is that I could be doing wrong.
Can you send the link to your doc?Senior Director, Technical Services, EMEA0
Here you go. Make sure all the units are consistent. The default is XYZ=0, but even if you're setting Z=0 it has to be 0 mm.
https://cad.onshape.com/documents/575767f45a035722142a0b73/w/c1fc1558e30faa1be54c2693/e/4270857cbd6f201da09b2191
3 -
Of course! I believe I made my document public and here's the link:NeilCooke said:Can you send the link to your doc?
https://cad.onshape.com/documents/d50e42cbee8def75b36c92e0/w/c51381cc9534edccbdb00ca4/e/f72791a89915a14e0234538a?renderMode=0&uiState=62824cd96d31f94cc5ed1d15
I haven't changed anything since I started having an issue, and maybe it's all just down to how I'm doing it.0 -
Thank you so much!mahir said:Here you go. Make sure all the units are consistent. The default is XYZ=0, but even if you're setting Z=0 it has to be 0 mm.
I'm not sure what my problem was but I'm glad to have a working epitrochoid document.
Again, Thank you so much!0
