Only 5 teams accessible for sharing?
Henk_de_Vlaam
Henk_de_Vlaam Member, Developers Posts: 269 ✭✭✭
I created 6 teams and to show the problem I also created team 'test'.
Now I want to share documents and folders with the 7th team ‘test’. However, before assigning I only get to see the first teams 1-5 I ever created. Team  6 and ‘test’ I can't reach. Is the number of teams that can be shared with limited to 5 or am I doing something wrong?
  • mfalkensteiner
    mfalkensteiner Member, Onshape Employees, csevp Posts: 87 image
    Well, this is super simple but - have you tried to type the name of the invisible teams in the dialog window when sharing....? Where it says "Search Names" in your screenshot.
    Principal Technical Services Engineer, EMEAI
  • mfalkensteiner
    Could you check if the team test that is not working may not have any team members assigned?
  • Henk_de_Vlaam
    @mfalkensteiner, Michael,
    No, team 'test' has no members yet. However, focus on the 6th team - which is blurred here - and forget team' test', which was only created to show a recognizable team in this topic.
    Team '6' has 3 members and myself as admin. Each member also shared a folder with the team. As said, I would also like to share a folder with that team but cannot access it.
  • mfalkensteiner
    Is it possible that the folder you want to share is a subfolder? Only top-level folders can be explicitly shared, and all Share details apply to the contents of the folder, including all documents and any sub-folders, even if they are moved into the folder at a later time.
  • Henk_de_Vlaam
    I all know. No, it's a top-level folder.
    In the meantime I also added a member to team 'test', but this team also remains invisible for sharing. So far still only 5 teams selectable.
  • mfalkensteiner
  • Henk_de_Vlaam
    edited January 2023
    @mfalkensteiner,
    That is it! Oh shame... how stuck can I be in my mind.
    Thank you very much for this simple solution.
  • mfalkensteiner
    Gladly - I admit, I also thought much too complicated here ;-)
