Can anyone tell me why I can't loft between these two sketches?
Try Loft as Surface, then Mirror, some Linear Pattern and Ticken.
https://cad.onshape.com/documents/8aa8ab28b193a114b923b987/w/03820bf23444bb729ff13446/e/dee198e5b430a5631bea44e7
1
It's probably because there are a lot more points on sketch 1 and the loft doesn't know how to match them. You can use Match Connections but I have done it another way. I'm sure there are a few ways to do this and someone else will have a better solution but for now here is my version
https://cad.onshape.com/documents/57b4bd7325dbab9bb8098d85/w/4862619a862ac72050051fc2/e/6e1e2059eb484fa60a814099
It’s really only a fraction which needs a loft or some other special treatment. Most of it could be a simple extrusion.I would loft a small piece of this, and then Boolean that together with the rest.
@GWS50 your document doesn’t seem to be public.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1 -
Ha...I knew I'd forgotten something...it's public now!!S1mon said:It’s really only a fraction which needs a loft or some other special treatment. Most of it could be a simple extrusion.I would loft a small piece of this, and then Boolean that together with the rest.
Thanks everyone for the answers. I used Dirk's solution.0
