const string value as map key?
imants_smidchensimants_smidchens Member Posts: 62 EDU
edited April 2023 in FeatureScript
Hi! I'm working on a featurescript that has a lot of maps for user inputs/calculations, and to keep things clean & organized, I've moved all the maps to a separate feature studio, which I then import.
To make things more robust & future proof, I'm defining some strings (which will be used in keys later) as constants, but unfortunately Featurescript insists that it can't find a key then.
for example:
const a = "foo";
const b = "bar";
export const DemoTable = {
   "name" : "table",
   "displayName" : "table",
   "default" : (a)
   "entries" : {
      (a) : "chose foo",
      (b) : "chose bar",
If I use strings for the keys, it works fine, but changing them to variables, even when wrapped in parentheses, results in the Feature Studio that imports these tables saying "Map entry has no key"
supposedly this should be allowed....
any suggestions?
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    It looks correct, other than missing a comma after
    "default" : (a)
    and a missing a semicolon at the end.  Public doc version that shows the error?
    kevin_o_toole_1kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565
    Your code is fine to use in FeatureScript runtime code, but defining FS parameters (in this case, a lookup table) requires specific syntax, since parameter definitions need to created before the code is run.
    So lookup tables specifically require their maps to be listed with literal string keys, not an arbitrary FeatureScript expression.
    Gotcha. Thanks for the info!
