How to straighten Plane 4 and Sketch 5
In the picture you can see that Plane 1 and 3 are square to the corner, but plane 4 comes out as skewed. I can do this off any of the faces of the square and it will all be square to that face, but it doesn't seem to work when trying it on the corner of the square. I'm guessing there is a better way to do this? To clarify, I'm looking for Plane 4 and the square in sketch 5 to be straight on like Plane 1 and Plane 3. Here is the link to the public file:
https://cad.onshape.com/documents/4fa8e253921d1f7f40e4ebbc/w/d229b1ca6fc510e5156b793e/e/ca90288682302625a5ae03ee?renderMode=0&uiState=6451e33e686efc6f02672d33
Thanks for any help!
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,436Use a mate connector instead of a plane - you have full control over axis orientation. MCs can be used anywhere a plane can.Senior Director, Technical Services, EMEAI1
Optionssteve_shubin Member Posts: 1,069 ✭✭✭✭@craig_sosebee
https://cad.onshape.com/documents/0b6562b2141f359a9ca490cf/w/291b25195c5b75b9d7c668cc/e/03d6bd9c3acf7376555d4d90
This document has a very useful custom mate connector
1 -
Using MultiMateConnector (MMC), It’s hard for me to make a three point plane.
I can get the center point of the MMC on plane with the three points.
But I haven’t figured out how to get the main axis (Z) of the MMC normal to those three points yet.
I could approximate the NORMAL TO aspect. But that’s about the best I could do at this point.
So there’s one reason for using the Plane tool. SEE POST BELOW
And I think there are other reasons for using Plane. For instance — doing an offset with the Plane tool is pretty fast.
1 -
Optionssteve_shubin Member Posts: 1,069 ✭✭✭✭@Ste_Wilson
Thought came to mind a little while ago. Tried it and sure enough, found out MultiMateConnector is ALSO CAPABLE of doing 3 Point Planes. AMAZING TOOL MultiMateConnector is !!
https://cad.onshape.com/documents/7c98eeba414f8f232cc74633/w/4284c0b456c6116855e9fff2/e/39d8a34de0bea26ef7d53dd61
I added one line to sketch 3 to provide a normal to pick for the sketch 5 mate connector. Note I still had to "realign" the secondary axis for the rectangle to be "straight".
https://cad.onshape.com/documents/1b5bac97caa393d19e395d8f/w/d36e041e5ab7e0ff6ce0bafb/e/deac2505962646a05dd4e60f
