Linear Mass Custom Property via FeatureScript
graeme_anderson
Member Posts: 12 PRO
I have successfully created a few lines of FeatureScript to take the volume of a 100mm long extrusion and output the volume per metre (including changing the units) using evVolume.
I want to do the same thing with mass per metre, but it appears evApproximateMassProperties requires a hard-called density, even though the part has a material assigned. I suspect this is why my FeatureScript compiles correctly, but the Custom Property it is linked to returns "computation failed."
FeatureScript code:
annotation { "Property Function Name" : "computeLinearMass" }
export const computeMass = defineComputedPartProperty(function(context is Context, part is Query, definition is map) returns string
var linearMass = evApproximateMassProperties(context, { "entities" : part, "density" : 1 * kilogram / meter ^ 3 });
linearMass = toString(roundToPrecision((linearMass / 100), 3)) ~ "g/m"; //convert part mass in kg to gram per linear metre, extrusion only, part must be modelled 100mm long
return linearMass;
return linearMass;
Have anyone found a way around this limitation?
You can debug custom properties by making a part studio with parts in the same workspace -- and then a custom table will appear with rows for the parts and a column for the property. At that point, you'll see errors with stack traces, and you can monitor/profile as with other custom tables.
Trying it shows that there was a units error, as well as evApproximateMassProperties returning several things besides mass. A working version is:annotation { "Property Function Name" : "computeLinearMass" } export const computeMass = defineComputedPartProperty(function(context is Context, part is Query, definition is map) returns string { var linearMass = evApproximateMassProperties(context, { "entities" : part, "density" : 1 * kilogram / meter ^ 3 }).mass; linearMass = toString(roundToPrecision((linearMass / (100 * millimeter)) / (gram / millimeter), 3)) ~ "g/m"; //convert part mass in kg to gram per linear metre, extrusion only, part must be modelled 100mm long return linearMass; });
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2 -
Thanks for taking the time to reply @ilya_baran, much appreciated.If I wanted to keep the kg part of the units, is it as easy as changing the "gram" to "kg"?Edit: Looking at the output, I'm not sure the conversion from kg to gram is working properly. I have a 100mm long part that is 0.138kg. The output of the code is returning 0.001 g/m when it should be 1380 g/m.
Yeah, except in FeatureScript you have to use kilogram, not kg. Also I just saw that in my example, I'm providing gram/millimeter instead of gram/meter -- that should be corrected.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Further to my edit above, how "approximate" is evApproximateMassProperties?
If the shape you're extruding is lines and arcs, it should be close to within floating point precision. If you have splines, it should still be very close -- you can try measuring manually and see the bounds, it's a similar precision. It's more approximate for more complex shapes and if you try to build using the value. For your use case, I think it's the right thing.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
I've updated the code following your advice, but the output still doesn't match the manual check.annotation { "Property Function Name" : "computeLinearMass" }
linearMass = toString(roundToPrecision((linearMass / (100 * millimeter)) / (gram / meter), 4)) ~ " g/m"; //convert part mass in kg to gram per linear metre, extrusion only, part must be modelled 100mm long from the Front Plane
return linearMass;
});Output should be 1380 g/m not 0.9 g/m. I think there is a problem converting from kilogram to gram or from meter to millimeter and I'm not sure which.
Ah, you're passing in 1kg/m^3 for the density. Try:
var material = getProperty(context, { "entity" : part, "propertyType" : PropertyType.MATERIAL }); var linearMass = evApproximateMassProperties(context, { "entities" : part, "density" : material.density }).mass;
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1 -
Problem solved! Thanks again @ilya_baran, much appreciated.
