offsetSurface FeatureScript Documentation Incomplete
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,945 PRO
    edited June 2023
    Here is an example of how you can use it:
    opExtractSurface(context, id + "extractFace", {
                                "faces" : yourQueryHere,
                                "offset" : 0 * inch });
    qThisSide = qCreatedBy(id + "extractFace", EntityType.FACE);
    And here is some more info about it:
    opExtractSurface (context is Context, id is Id, definition is map)
    For Onshape internal use.
    This function takes a list of faces and creates one or more surfaces from those faces. The source faces and body are not affected.
    PARAMETER INFO
    definition is map
    - faces is Query
    List of faces to be converted. If tangentPropagation is true, these are the seed faces.
    - tangentPropagation is boolean   optional
    Whether additional faces should be added to the selection by tangent propagation
    - offset is ValueWithUnits   optional
    Offset extracted surface faces by this distance along normal
    - useFacesAroundToTrimOffset is boolean   optional
    Use surrounding faces extensions to trim offset. Default true.
    - redundancyType is ExtractSurfaceRedundancyType   optional
    Controls the culling of redundant geometry on the result body, such as tangent edges and vertices. ALLOW_REDUNDANCY does not delete any redundant geometry. REMOVE_ADDED_REDUNDANCY removes redundancy created by this operation. REMOVE_ALL_REDUNDANCY removes all redundant edges and vertices. REMOVE_ADDED_REDUNDANCY is the default.
    RENDERCAD
  • EvanReese
    EvanReese Member, Mentor Posts: 3,068 PRO
    I didn't realize this had built in tangent propagation. Thanks, Michael!
