offsetSurface FeatureScript Documentation Incomplete
Jonathan_Hutchinson
Member Posts: 162 PRO
Here is an example of how you can use it:opExtractSurface(context, id + "extractFace", { "faces" : yourQueryHere, "offset" : 0 * inch }); qThisSide = qCreatedBy(id + "extractFace", EntityType.FACE);And here is some more info about it:opExtractSurface (context is Context, id is Id, definition is map)
For Onshape internal use.This function takes a list of faces and creates one or more surfaces from those faces. The source faces and body are not affected.PARAMETER INFO
definition is map
- faces is Query
List of faces to be converted. If tangentPropagation is true, these are the seed faces.
- tangentPropagation is boolean optional
Whether additional faces should be added to the selection by tangent propagation
- offset is ValueWithUnits optional
Offset extracted surface faces by this distance along normal
- useFacesAroundToTrimOffset is boolean optional
Use surrounding faces extensions to trim offset. Default true.
- redundancyType is ExtractSurfaceRedundancyType optionalControls the culling of redundant geometry on the result body, such as tangent edges and vertices. ALLOW_REDUNDANCY does not delete any redundant geometry. REMOVE_ADDED_REDUNDANCY removes redundancy created by this operation. REMOVE_ALL_REDUNDANCY removes all redundant edges and vertices. REMOVE_ADDED_REDUNDANCY is the default.
RENDERCAD
rendercad.ai - Photorealistic product rendering.
________________________________________________________________________0 -
I didn't realize this had built in tangent propagation. Thanks, Michael!1
