Seeking featurescript for: select 3 points, automatically generate triangle surface face
jack_scalise
Member Posts: 1 ✭
Does anyone know if something of the like has already been made by someone? I am seeking the ability to select 3 points anywhere on my model, then fill a triangular face there. I am currently using bridging curves and the fill tool, but would like to consolidate down to a single feature as this is a relatively frequent action of mine.
Just whipped this up. It takes any number of points, but the selection order matters. https://cad.onshape.com/documents/83ce1fe48557406a1747ca62/w/722dfa9963d4d213ef50bedb/e/0558a4df33504e0fddc673853
▚▞▚▞▚▞▚▞▚6 -
It probably took longer to make that gif than the featurescript
3 -
almost certainly, lolmahir said:It probably took longer to make that gif than the featurescript
