Where is the Internal Thread function to match the External Thread function?
dan_vardell
Posts: 4 ✭
I'm not clear why Internal Threads are not an option with External Threads. Or an option under Hole. This need is so obvious I'm sure I'm missing something.
You can add cosmetic threads under the hole option. Off the top of my head.. You can select drill, clearence, tapped. Make sure you select tapped.
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0 -
Thanks. Unfortunately, I need to model threads. ThreadLab is useful but limited in this regard. Seems an odd gap -- but an opportunity to practice my sweeps!0
Have you tried thread creator feature script? I think that's the most developed, but I might have missed an update!
https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/c953720c264ce001f1a82dc1
