Issue while using "globaltreenodes" API for trash in Onshape storage
Actually I was trying to use the native onshape APIs for trash but for some reason I am getting the "forbidden" error.
I am using these 3 APIs.
https://cad.onshape.com/api/globaltreenodes/restore
This works fine.
But I am getting 403 (Forbidden) for these 2 requests, I am using the same type of auth and respective json body.
https://cad.onshape.com/api/globaltreenodes/emptyTrash
https://cad.onshape.com/api/globaltreenodes/delete
For eg, for /delete -
My body is -
<div>{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;"itemsToMove":&nbsp;[</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;"resourceType":&nbsp;"folder",</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;"id":&nbsp;"087c742dd84d5eae353d6e2a"</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;]</div><div>}</div>
Can anyone please help here, what could be wrong ?
  • caden_armstrong2
    caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    edited September 2023
    You can delete folders with the /magic/4 endpoint:
    POST https://cad.onshape.com/api/globaltreenodes/magic/4
        "itemsToMove":[
            {"id":"b7c7aeee4c2b2bacf255d71f","resourceType":"folder"}
    Just make sure that your OAuth application in the dev portal has permission to delete
  • aman_singh005
    aman_singh005 Member Posts: 11
    Thanks for the response.
    So, this "delete" is for the trash, right ? I mean it will delete the folder forever ?
    I guess it's a normal delete.
    Also, can you please let me know if there is a way to empty the trash using any APIs ?
    Or if you can provide me some documentation, that would be great help.
  • caden_armstrong2
    As far as I know, there's no way to empty the trash via the API.
    The /delete api for removing from trash seems to not be a publicly accessible API.
    These APIs don't exactly have documentation, and are likely not officially supported.
    Onshape has more than a few APIs that are not publicly accessible.
  • aman_singh005
    Okay, I am getting your point.
    So, is there any alternative or anything you might help here ?
