Dealing with subassemblies in an assembly
A) is a minor annoyance. When I insert my first Assembly into my main assembly, I learned through trial and error that if I "fix" any one part in that subassembly it in turn fixes the entire subassembly. While this works, it feels odd that I can't "fix" the subassembly in the model tree but only a part in that subassembly. Am I missing something? This isn't my primary issue though...
When I insert the new subassembly, even though it is fully constrained within it's own assembly, it comes in unconstrained in the main assembly.
So when I try to mate this new subassembly to the other subassembly, it only moves one part - not the entire subassembly
There has to be a fix for this short of re-assembling the entire subassembly in each assembly it's used in.
Any advice?
Fix is not a mate (which is why it's not in the toolbar) - it is a "temporary constraint" to stop parts moving around while you fasten or group them together. As such, a fix "constraint" does not do anything at the next level up - confusing I know.Senior Director, Technical Services, EMEA1
To add to Neil's comment, after fixing one part in your "Full Tiller Subassembly", you can use the group feature to fully constrain the other parts as well. Given there are motions between them, then as he said you would need to fasten them accordingly.
Most likely your subassembly is overdefined with multiple fix "constraints" which does not effect higher level assemblies or has degrees of freedom which allows the parts to move. Grouping parts removes this freedom.
@David_YL_Nguyen / @NeilCooke
I understand this and I understand the group command. I can't understand why when one assembles a subassembly into another subassembly why the parts aren't automatically grouped!!! Isn't that the primary function of any assembly?? This is the way that Solidworks and other cad systems I've worked with work. I know the people who designed Onshape aren't dumb so there must be some logical reason why when you assemble an assembly into another it isn't inserted with those parts in fixed relationship to one another. But it doesn't make any sense to me and leads to all sorts of ugly work arounds.
For what it's worth, it would be cool if when you assembled an assembly into another there was an option to bring in that assembly grouped - that would have made more sense to me than to force someone to assemble an assembly and then immediately have to group it so it behaves like a single unit.
For that matter, the absence of planes in an assembly (and the inability to access the subassembly model trees) in Onshape also drives me crazy. I'm constantly struggling with assembling parts and subassemblies because of this. I have countless times where I need to create a "fake" cube and assemble it into my main assembly just so I have some orthogonal planes to work off of. Again - maybe I'm missing something here.
Again, I know I'm a victim of my previous experience and I'm trying to un-learn my previous workflows but these are things that make Onshape really frustrating until I can better understand how they wanted this to be handled!
Dave1 -
@NeilCooke
If "Fix" is not a mate, how do you "start" assembling??? Unless I'm missing something (which I probably am) I don't have access to any planes in an assembly - just the origin. That's fine if I want to assemble something to the origin but there are plenty of times I don't want to do that.0 -
The difference with Onshape is that subassemblies are effectively “flexible” - to use Solidworks terminology - all the time. It does take some getting used to, but overall I’m much more happy with Onshape assemblies than I was at first. It’s certainly one of the bigger changes coming from other tools.
Let's say one subassy is a caster, consisting of: wheel, brake, swivel, sheetmetal body. You have it fully constrained except you allow the wheel to swivel 360 deg. Now you insert that caster sub into a higher level assy. The wheel will still be allowed to swivel in this higher sub. That's the reason.1
You can create/reference a mate connector on the origin of an assembly directly, there is no need for a "fake cube". Use the shift key to help set the z orientation on the origin.dave_franchino said:@David_YL_Nguyen / @NeilCooke
... I have countless times where I need to create a "fake" cube and assemble it into my main assembly just so I have some orthogonal planes to work off of. Again - maybe I'm missing something here...
I wasn't convinced at first either (also came from SW) but the assembly environment in Onshape is actually nicer to work with. It's a lot cleaner without all the extra crap in the tree. While there is the occasional time where it would be useful to access the "part level stuff" in assemblies, most of the time it just gets in the way and when I go back to SW I find myself endlessly scrolling around the tree looking for the stuff that actually matters.
The key is to get comfortable with working with mate connectors (i.e. creating explicit ones and also editing implicit ones), the only thing I dislike in this area is sometimes having to create a mate "wrong" in order to be able to edit the mate connectors after the fact... If we could edit the individual mate connectors directly from the mate dialogue it would really streamline things (as described here: https://forum.onshape.com/discussion/16715/add-option-to-edit-mate-connectors-from-the-mate-dialogue). Here's a discussion of the "finer points" of mate connectors that I didn't find were adequately covered in the training.
There is the odd case where the mate connector system can be slightly less "natural" but in the vast majority of cases it's superior (a lot easier to fix mating errors when you don't have multiple mates between the same part fighting each other!)
Having degrees of freedom translate upwards in the assembly structure is actually really nice and opens up a lot of things, as @S1mon put it, all assemblies are "flexible" in Onshape and I would argue it's not "natural" for a sub-assembly to become "frozen" when you insert it into a higher level (I believe the main reason SW behaves that way is for performance reasons, and the "flexible" option was added later to help get around that limitation...)!
All you need to do is ensure is all the parts in your sub-assembly are fully constrained relative to each other (i.e not by "fixing") if nothing needs to move a single group relation is all that is needed and then you just need one relation in the higher level to constrain everything I'm not seeing what "ugly workarounds" you are talking about...
Also note that if you have a sub-assembly that has some degree of freedom, you can still control it from a higher level with named positions, configurations (in the sub-assy) or adding a top level mate. The key is to not constrain more than necessary so if you have a revolute mate in the sub-assembly, you can add a cylindrical mate with rotation limits to further constrain it in the top level. Overall it provides a lot more "flexibility" in the way you can structure an assembly to represent "real world" than when the sub-assemblies become rigid by default!
@nick_papageorge073, with all due respect, I might argue that if a caster can move independently then it should be its own sub assembly and not part of an upper level assembly. I've always tried to make my sub assemblies match what I believe the final manufacturing sequence to be. And so the sub assemblies would mirror individual assemblies that there would be assembled into a final master assembly. I fully understand their limitations to this and that isn't always a rule that can be followed, but in general i believe it's much more common for a sub assembly to be constrained as a unit within a master assembly. That's really sort of the point of creating a sub assembly and assembling them into master assemblies, isn't it? It's really just a stylistic thing. I can work around it but I still find it kind of annoying.0
From a BOM standpoint, yes. But from a functional standpoint, you lose flexibility. I'll give you an example. I used Creo for 15 years at my prior dayjob designing motorized swings that rock infants to sleep. Getting the final top level assy to "swing" like the real physical swing did was pulling teeth. We never even attempted it in CAD, except on the one last project I worked on at that company in 2017. In OS, that would have been as easy as pie, because each higher level assy respected the motion/mates of the lower level assy's within it.dave_franchino said:@nick_papageorge073, with all due respect, I might argue that if a caster can move independently then it should be its own sub assembly and not part of an upper level assembly. I've always tried to make my sub assemblies match what I believe the final manufacturing sequence to be. And so the sub assemblies would mirror individual assemblies that there would be assembled into a final master assembly. I fully understand their limitations to this and that isn't always a rule that can be followed, but in general i believe it's much more common for a sub assembly to be constrained as a unit within a master assembly. That's really sort of the point of creating a sub assembly and assembling them into master assemblies, isn't it? It's really just a stylistic thing. I can work around it but I still find it kind of annoying.0 -
Sorry to resurrect this but I think if I could learn to do something simple it would make this a lot easier for me. How do you select the primary axis when creating a mate connector.
In other words, if I create a mate connector at the origin it orients the Z axis facing upwards. I have the option to flip it so the Z axis is pointing downwards but what if I want the X axis to be the vertical axis? I'm sure there's an easy way to do this but I can't figure it out. Above someone mentions using the shift key but what does this do? On my computer pressing the shift key in the middle of this doesn't seem to do anything. What am I missing?
Thanks!0 -
In the part studio or assembly. Under the move selection you can rotate the axis while generating a Mate connector,
@eric_pesty, please elaborate on, "Use the shift key to help set the z orientation on the origin". Any tricks or shortcuts for orienting a mate connector would be greatly appreciated.
@matthew_stacy
Holding the shift key once you are over the origin when creating a mate connector keeps you "locked" to that point making it much easier to pick the Z orientation (watch for the "up arrow" below my cursor when I hold shift and notice how the origin stays in focus as I move the mouse away from it):
Holding the shift key in general when selecting any implicit mate connectors will lock the entity you are over making it easier to pick the item you want. Trying to pick these center mate connectors can be very difficult without using shift.
Thanks @eric_pesty. Good stuff!
@glen_dewsbury,
I was aware of the ability to use rotate but unless I'm mistaken you're only allowed one "rotate" for a mate connector. I'm working on a sailboat rudder where the sailboat transom that the rudder is mounted to is angled at 5 degrees. It's a lot simpler to design the rudder at zero degrees (orthogonal) and then assemble it to the boat at 5 degrees but when I create a mate connector on the rudder the z axis is pointing along a different direction than the mate connector created at the origin. I just want to be able to specify which axis on the mate connector is pointed up.
I can work around this but it's just a bit frustrating and cobbled so I was hoping there was a clean approach I was missing.
I want to be clear I'm not whining about onshape. There's plenty to like but I just have some things to learn to make my modeling smoother
@eric_pesty,
How do you "pick" the z axis origination?? That's the missing magic I'm not sure how to do!!!
Dave
@dave_franchino
If you are using the origin in an assembly you can move your mouse to make it point in one of the three front/right/top directions On anything else (including the origin of a part studio), you have to edit the mate connector and use the "realign"/"move" options.
If creating a mate, you have to create the mate first before you can go back and edit the mate connector. There some examples of that here:
https://www.youtube.com/watch?v=HUVFq7tixKM&list=PLa8CoVttf7wXCNXE5PsZIz7JONSrUJvJj&index=2 1 -
A simple way to do this is realign using a sketch or an edge of something existing in the part studio. You can realign and move and rotate all at once as needed. When you edit in context other edges can be used. Watch Eric's video, it's worth the time.dave_franchino said:@glen_dewsbury,
https://cad.onshape.com/documents/8932a4a3d3645f4d7839a3fd/w/98826c63ff7862ce2db475d1/e/f58b23ce623e36ef83aadd62
Is there a training module that explains the "recommended" method of dealing with subassemblies? I keep thinking I've got assemblies figured out, only to have mates and group begin behaving strangely. Then I read forum topics like this and get confused all over again. It's driving me crazy and it seems like the assembly "system" was designed to be used in a way that is not adequately explained anywhere.
Hello @Adam_Reed_Erickson . Small world.
There are a couple things that are a bit different from Solidworks that made my initial experiences with Onshape assemblies maddening. They now mostly seem good, but different.
- Onshape subassemblies are "flexible" by default (to use SWX terminology). Relatively recently there's a new option to create an assembly from a part studio where everything in the part studio comes into the assembly locked in position based on the part studio, but otherwise, everything moves around.
- Onshape's "Fix" only does something in the assembly it's in. When that assembly becomes a subassembly, the "fix" essentially doesn't do anything anymore. In general, I would just avoid using "fix" except as a temporary fix. You can drop a bunch of parts into an assembly and fix them all, and that's fine, for that assembly only. It's a $@#@show when that gets put into another assembly. If you want a bunch of parts - especially an imported assembly - to behave in a predictable way, you can group all the stuff that's in the right location, but you need one part to be fixed or preferably mated to the origin in some way.
- In general, I like to create a Mate Connector at the origin of an assembly, so I have an easier way to attach things to that. Then I will at least mate a major part to that MC. Other parts could all be mated in functional ways to that main part, but then there's the risk of what happens if that core part blows up or gets replaced. Sometimes I like to mate things to a skeleton sketch (you can assembly sketches in Onshape assemblies).
- In a production database, name your mates, so you don't loose track of what's what. Also group them in folders where it makes sense.
- If you're doing things in a master model approach via derived parts and/or multipart studios, especially with stuff that's not super mechanical, consider adding MCs in the part studios at a reasonable "origin" so you can mate that in the assembly. The MultiMateConnector custom feature is pretty useful for adding MCs to a bunch of parts in one feature.
Feel free to ping me separately - we should catch up…
