Continuous Connecting points with a line
luk_kuk
Member Posts: 10 ✭✭
I've been looking for two days but I can't find it :-(
I create several points with the USE function and I want to connect them continuously with a line. I will point to the first point (it will be yellow), I will point to the second point (it will be yellow) and create a line. From the second point I want to continue further to the third point so that I don't have to point to point 2 again. How can I do this? I need to connect a lot of points.
@luk_kuk please share a link to your document so that we can help you better.
It sounds like you need a sketch Spline.
▚▞▚▞▚▞▚▞▚0 -
Click and drag each segment.Senior Director, Technical Services, EMEA0
Yes, SPLINE behaves as I need, but it cannot make a straight line. Or can it? ;-)
