Creating a pattern on a curve
mark_richards818
Member Posts: 5 ✭
when I select the feature and the edge of the extrusion and then input the instances... what is the red outline of the feature adjacent to the original feature? it creates all sorts of problems for me..
Can you share a public link to an example of the problem you are having? It could be due to many factors (one which might be fixed with the click of one checkbox), but diagnosing without seeing anything is going to be tricky...0
