how do I connect lines into a "polyline"
david_perich
Member Posts: 2 ✭
How do I connect separated lines into a rectangle?
Are you trying to do this using feature script or manually in the modeling workspace?
In featurescript, you'd want to use skPolyline() to outline the entire profile - make sure that the first and last points are the same, I sometimes forget that part.
In the modeling workspace, you'd simply add lines to your existing sketch using the line tool.0
