how do I connect lines into a "polyline"
How do I connect separated lines into a rectangle?
  • Stormi_Backus
    Stormi_Backus Member Posts: 49 ✭
    Are you trying to do this using feature script or manually in the modeling workspace?
    In featurescript, you'd want to use skPolyline() to outline the entire profile - make sure that the first and last points are the same, I sometimes forget that part.
    In the modeling workspace, you'd simply add lines to your existing sketch using the line tool.
