Assembling imported parts
amit_kaistha
Member Posts: 4 ✭
Hello All,
First time here. I have imported a few parts into on shape but they are in different workspaces. How do I assemble them?
Looks like you pick a fairly complex issue for your 1st problem. First of all I don't believe that this is what the work spaces are intended to be used for. With that said,if you create a new blank work space then merge each workspace into the new one. In the new workspace you can create an assembly using the merged parts. This type of workflow has issues when attempting to merge complex subassemblies but for single parts in seperate workspaces it should work.
All three files are located in the same "Workspace"
I go to the Base_Bot file and under assembly mode I am unable to see these two parts
What am I doing wrong?
Thanks for your help
What he is calling a workspace appears to be his entire document list. Of course this doesn't invalidate your advice.
1) When importing any number of external documents, you can either import them one-per-document OR, by initiating the import from inside a document (click on the '+' in the bottom left hand corner) you can import them one-per-tab.
2) Where you have data in multiple documents (perhaps even 'standard' parts), it is entirely possible to copy them from one document to another. By RMB clicking over the part studio tab name (at the bottom of the screen) there is an option to 'copy to clipboard'. In the target document, click on the '+' and select 'paste tab' - BOOM!
3) In any given document, the ability to 'derive' a part or sketch from one part studio to another ASSOCIATIVELY and at any point in the feature history of a part studio is exceptionally powerful.
After that use RMB on the part studio tab and select "Copy to clipboard" then go to Base_bot, click on + sign and select "Paste tab". You will get those exported parts in the same document in different part studios, so that you can use them in assembly.
In case if the parts are created with Onshape, there is no need to export them. Just copy and paste will work. But there is no link between original and copied part.
(or anyone who is confused)
In document list shown below, the Column header "Name" refers to Document name.
The adjacent (grey) "Workspace" is actually another Column header. In your example, it shows that all the documents listed either have only one workspace (which by default is called "Main"). For a user who has created other workspaces. in the case of documents which when last closed were revealing another workspace, this column will show another name.
It might help comprehension if Onshape were to rethink the layout slightly. It wouldn't hurt if the word "Documents" featured more prominently (currently buried in the URL)
And perhaps a plus sign between Doc Name + Workspace, in the column header ?
It seems to me the lack of column dividers means some other cue is needed so the use does not think that "Workspace" is an explanation attached to the heading "Name".
Workspace is not strictly a separate column, but an appendage to the Document Name column, as the above graphic demonstrates.
I wish it were possible to resize the Name + Workspace column wider. It's often only the last few words of a Document name which differentiate it from other related documents, and a wide monitor offers minimal advantage under the current layout.
