Extrude not working - with error Edges can only meet at there ends
adam_carlson684
Member Posts: 2 ✭
I am a noob and am building a part with two separate sketches that need to be able to touch/intersect. The first sketch extrudes just fine. I have tried to make sure my second sketch does not have overlapping lines, and intersect correctly. https://cad.onshape.com/documents/455a705d34c61e5f6c6e3fdd/v/0736d487ccb7fa165f9e4711/e/f83b9369f75291bd123157fc
When extruding the honeycomb should resemble that of a car grill. Just trying to get about half inch of extrude on grill.
If you zoom in very close, you'll see that some of the edges do overlap.
The easiest way to make a hex grid is with a custom feature, like this one: https://cad.onshape.com/documents/2f390754b9d0cbf7c2dc4128/w/49cd82f65be2b44294988bd4/e/a5591b0ec218d2a4f47a059d0
