sheet metal bending drawing
alex_vesta
Member Posts: 4 ✭
Hello, I am new in OnShape.
I'm trying to create sheet metal bending drawing, like this example. Thickness is 3 mm, also rounded corners. The detail is simple, but I got confused in numerous settings and templates, and the help tooltips don't look clear enough. Can anyone help me?
https://learn.onshape.com/learn/course/introduction-to-2d-drawings/drawings-interface/introduction-to-drawings
Just Copy and edit, adjust the dimensions to your liking and you are ready.
Use the rollback bar in the Partstudio to see how it is done.
After that go to the drawing and click on update
The drawing update button is on the left top corner.
And maybe its better to have a look at the learning center or do the Quickstart
The editing of all the parameters, dimension,s angles you do in the Part Studio.
And then you create the Drawing with all the neccesary view's and dimension's.
You only have to do this once, after editing the Part Studio just click the yellow update icon.
https://cad.onshape.com/documents/d7b1b8692866df96cbe6053d/w/f06bc1656a6a51d877776b2d/e/aab2055482980d4ec9195f01
In Part Studio1 tab, which left menu I should right click and edit:
Scetch1
Sheet metal model1
Scetch2
Scetch3
https://cad.onshape.com/documents/f1812ca7a1a085208fd2687b/w/02a1d36a6eb5ab4ceddd022e/e/67690d76a0ff9fa91978ef52
