It refuses too chamfer because it's "self intersecting"
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    I can,t see what the problem is because you need to share your document first.
    But in the view I can see that you just started with your design, and may be there is something wrong with one of these sketches.
    And another tip don,t use chamfer for designing, if you want it in the design put it in your sketch
