How to create perforations along a curved solid?
ignas_savickas420
ignas_savickas420 Member Posts: 2
edited October 2018 in Community Support
What is the best way of creating perforations along a curved solid? The pattern along curve tool does not appear to work. Perhaps I am making some mistake somewhere? Any help would be much appreciated.
https://cad.onshape.com/documents/5e44989120f8c9dbf35ccf13/w/a90e308604f6154bbd8f98ea/e/cd662d85f63bc642da0cb2d9
TL.DR
I would like to know what is the best way to repeat hole every 14mm along the solid.
https://i.imgur.com/0EaNHFp.png
  • ignas_savickas420
    NeilCooke said:
    Create it as a sheet metal model, then sketch/pattern the holes on the flat
    Your answer has been most helpful. Thank you so much.
  • owen_sparks
    Get used to it, Neil's like that :+1:
    Owen S.
    HWM-Water Ltd
  • lukas_szwugier
    lukas_szwugier Member Posts: 11 PRO
    @NeilCooke I make exactly the same for much more quantity of holes I need a perforated Sheetmetal but it need to be bend (see pic under).
    After make such approach regeneration time is 296s :#.
    DO you have some different approach for those type of models?
