Holes on Curved surface mate to holes on flat surface.
brian_pinder662
brian_pinder662 Member Posts: 119 ✭✭
I have a Curved wind turbine blade with two connecting holes. I am trying to mate to a flat surface with corresponding holes. Can anyone say if this is possible or maybe suggest how this can be done. the wind turbine is only a model  which I am using as a continued learning project into Onshape. Blade and bracket have been modelled in sheet metal.It is the outside of the curve that needs to be to the flat surface.
Thank you   Regards Brian
