Extrude at an angle?
MrMike_
Member Posts: 5 ✭
Hi, sorry if this is a stupid question, this is my first attempt at 3D models. I have a triangle, I want to take a slice from the hypotenuse edge from 0mm to the right angle corner at 1mm depth. I can extrude from either of the faces but this doesn't give me what I want. I hope you can understand.
https://cad.onshape.com/documents/dbca291eb8a92f9eb426981f/w/44e63102e3563e644de2fc33/e/52adb8828fa70969b76d39af
Thanks
Thanks
Hi @michael_snabel welcome to Onshape!
You can either use the Draft feature (and work out the face angle to get the desired depth of cut) or Loft like this:
Does that help?Senior Director, Technical Services, EMEA8
Does that help?Senior Director, Technical Services, EMEA8 -
Perfect! I watched many tutorials but never saw anything that demonstrated this tool. Thanks for your help Neil.0
