Self pace tutorial - exercise Inserting a BOM Slide 6
In step 6 it calls for you to create callouts in the assembly drawing. There is no icon for callouts in the assembly drawing - only in the drawing tab.
Also the menu when you make the copy of the Hydraulic clamp is not expanded like it is in the exercise. BOM is in a drop down menu in the copy and not easy to locate.
  • john_mcclary
    Correct, the callout icon is only in the drawing tab.
    The menus will collapse into drop down menus if your browser window is too small (Or your screen resolution is too small)
    The wider you make the window the more Icons you get in a row without any drop downs
    https://www.youtube.com/watch?v=wzpnOXErOg0
