problem
I'm trying to hollow out a cube but it stops a few millimeters from the bottom. Am I doing something wrong with the Shell tool or is there another tool on Onshape that I should use, if so can you please tell me want it is?  :):):):)
    The shell feature will remove the face you select and offset every other face by the value you enter. If you want 2 faces open (front & back) select both faces.
