Could / Should Gitflow and Release Management coexist?
andrew_kleinert
Member Posts: 97 PRO
I'm currently looking into Release Management and wondering if the Gitflow and Release Management processes could / should coexist?
Does the inbuilt Release Management process supersede any point to using Gitflow? Or would there still be some point to still using Gitflow?
Does anybody have experience with this?
(FYI @mlaflecheCAD )
I've watched the two very good webinars on Gitflow and Release Management in detail ...
https://www.onshape.com/videos/office-hours-with-the-professor-episode-2
https://www.onshape.com/videos/introducing-release-management-and-approval-workflows-040518
... but it's left me with a bit of confusion about if / how the two workflows could / should work together.
+1 for this (FYI @michael_mcclain )KatieHuffman said:@michael_mcclain , thanks for the feedback. We are working to create more learning materials around the release management capabilities for Pro and Enterprise users. Those two tech briefings are still valid for Standard users, who may want to achieve releasing an object with a more manual method by setting the properties. You will see a new release management class available soon, and from there we will be able to create more material.
2
mlaflecheCAD
Member, Onshape Employees, Developers Posts: 208
Let me whip up another example quickly, the link in my entereprise account prevents the version graph from showing up. But here is what it would look like
Regards,Mike LaFleche @mlaflecheCAD5
Partner de PTC - Onshape Averigua a quién conocemos en común
I'm still playing around with it - there's a bit of detail in the revision management process to understand and absorb.
