Best Way to Mate Coplanar Pulleys on Different Shafts
steve_cohen
Member Posts: 29 EDU
I have two pulleys on parallel shafts. I want to mate each one to be concentric with its shaft, but I want the faces of the pulleys to be mated to be coplanar with each other (the belt will line up with both)
Is this one of those situations where more than one mate is needed to do what I want?
Yes. Just add a planar mate between the two pulley faces.Senior Director, Technical Services, EMEA5
Thanks much!0
