Need help troubleshooting png insertion
anthony_welton
Member Posts: 9 EDU
I have imported a png file, and the preview of it looks correct, but when it try to insert it via "insert image" it just shows up as a gray square. Any suggestions?
Please share a link to your doc and someone will have a gander.Cheers, Owen SBusiness Systems and Configuration Controller
HWM-Water Ltd0 -
Hi.Looks OK to me, are you still having problems?
Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
Here it is on my end in firefox.
Hmm, I see your point, that's not right. I'd open a support ticket and see what the professionals say at this point. The good news is they tend to be pretty quick. Sorry, Owen.Business Systems and Configuration Controller
HWM-Water Ltd0 -
@pete_yodis can you offer any advice here please? Ta, Owen.Business Systems and Configuration Controller
HWM-Water Ltd0 -
@anthony_welton does this post help at all? https://forum.onshape.com/discussion/comment/42904#Comment_42904
Senior Director, Technical Services, EMEA0 -
No sir. Performance isn't too shabby, and everything else is working fine. Thank you for the link thoughNeilCooke said:@anthony_welton does this post help at all? https://forum.onshape.com/discussion/comment/42904#Comment_429040 -
I think I found the problem, at least on my hardware. I tried several different png files and they all worked just fine. I'm not sure why that particular file worked for @owen_sparks and not for me, but it probably has something to do with the combination of Arch Linux and Firefox. The png that was giving me problems was also converted from a pdf.
Who knows. I'm calling this one a fluke. Everything I have tried that wasn't a pdf conversion is fine.
Thanks for all the help! This seems to be a wonderful community.0 -
Sure thing, it's like that here
Cheers, Owen.Business Systems and Configuration Controller
HWM-Water Ltd0
