BOM
Hello
When I make BOM to assembly, why the column "Part number" is empty?
    Are you sure the correct part property is set? Part number is not the same as part name.
  • dan_schwartzdan_schwartz Member Posts: 16 ✭✭
    I didn't fill the "Part number" field in the property.
    Dan
