Export a dxf with shading.
igor_vinograd
igor_vinograd Member Posts: 4 ✭
I'm trying to generate a dxf to use in a laser cutter. Instead of cutting, I want to use the laser cutter to burn a picture into some wood.
It was super easy to make a 3D model, make a drawing from it and then export a dxf. I added shading in the drawing but it does not translate to the dxf.
Is it possible to export the shading into the dxf?
  • igor_vinograd
    NeilCooke said:
    Short answer is no - just lines, arcs, etc. How did you add shading to the drawing? Just a shaded view?
    Yes, it was the shaded view.
