Assembly. I need a dimension in a part to change -relative to the position of an other part .
In an assembly I have a curved (like a more or less flatten S) leaf spring fixed in one end. When a tube is sliding along the leaf spring from the fixed end, the leaf spring should give way and be totally flatten.
I have made 2 configurations controlling the offspring dimension in the leaf spring part (max. and min.) Both in the sub assembly and in the top assembly.
I can make an animation for the tube movement?
Thanks
Peter
  • peter_hansen527
    peter_hansen527 Member Posts: 5 EDU
    Thank you for the answer!
    It was what I feared/expected :(. I will make a series of configs...
    NeilCooke Moderator, Onshape Employees Posts: 6,078 image
    edited March 2019
    @peter_hansen527 rather than create a series of configurations, try driving it from a configuration variable. The variable could drive the position of the tube and the deformation of the spring. You could then just change the variable without having to create a huge table.
