hole callout edit
bikr7549
Member Posts: 24 ✭✭
Hi,
The hole callout allows a prefix note of up to 24 characters to be added. Is there a way to add a suffix as well, or instead? For a tapped hole I like to add the hole qty in the pattern after the tapped hole spec along with a note after this such as '4X, EQ SPACED, LOC AS SHOWN'. Qty ok to be a suffix, but the note part I would prefer to be a suffix addition. The whole thing can be whittled down to be a prefix but this simply looks odd to me. Is there a way to add in a suffix that I have missed?
Thanks,
Bob
Thanks,
Bob
Currently you can use the dimension tool. Or type it all out in a note. You can create an IR, but I think one exists already.
