Importing a zemax step model into onshape.
avihu_goral
avihu_goral Member Posts: 19 PRO
I have a zemax model in step format. The model includes many lines (14000).
1. Importing is very slow
2. How i insert the lines into an assembly
  • avihu_goral
    seems that onshape supports insertion of solids and surfaces only.
  • romeograham
    romeograham Member, csevp Posts: 783 PRO
    You can import DXF / DWG files as well. They can be imported as drawings / sketches.
    If you can export the model as a solid it will work.
    You can insert an instance of a Sketch into assemblies once you have some sketches.
