What is the best way to copy this shetch to another plane in the same position
aa_bb671
aa_bb671 Member Posts: 3
I would like to copy selected sketch as in the picture. What is the best way to do it? Or maybe I should change order of what is done?
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,100 PRO
    edited May 2019 Answer ✓
    You can right click the sketch and copy sketch
    Then you can paste it on the new plane and move it in position
    Depending on what you're doing, I might suggest extrude->new your sketch then do a transform or pattern with a remove or add.
    That would save a sketch and make it more parametric.
  • aa_bb671
    edited May 2019
    Thank you for answers!
    To be more precise, I would like the copy to change when I change original.
    So I think circular pattern may be best practice in this case, isn't it?
    Or maybe if I need to extrude it anyway it is best to use tranform tool?
  • Cris_Bowers
    Cris_Bowers Member Posts: 281 PRO
    Assuming you are creating a feature from the sketch @john_mcclary 's answer is probably better. Here is a handy dandy featurescript to help https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/v/ffa0b06304c5fc3946d3536a/e/a71ff51699ae36f356a38f69
