Can we export assemblies in .sldpart format?
chand_basha
Member Posts: 66 EDU
Hi all,
One of my Clients is asking design files in the .sldpart format. But Onshape will support .sldpart for only part Design. How can I export Assembly design in .sldpart Format?
Many thanks,
Regards,
Chand
Many thanks,
Regards,
Chand
Export as Parasolid. SolidWorks will open it just as if it is a native SolidWorks assembly. Make sure you use an earlier version of Parasolid such as v25 in case they are using an old version of SolidWorks.Senior Director, Technical Services, EMEA6
Thank you!0
