Revolving about axis through center
leos_pohl
leos_pohl Member Posts: 2 EDU
If I have a rectangle, why cannot i revolve it about the axis going through the middle of on of its side but only about an axis going through one of the edges? In the example below, the rectangle cannot be revolved about the selected construction line but it can be revolved about the other construction line.
  • bruce_williams
    The answer is similar to @NeilCooke response here - https://forum.onshape.com/discussion/comment/54542#Comment_54542
    If you draw a solid line on the construction line you create a closed region of 1/2 the rectangle and this can be revolved.  The other 1/2 of the sketch rectangle is not needed.
    www.accuratepattern.com
    NeilCooke Moderator, Onshape Employees Posts: 6,099 image
    When creating a sketch for a revolve, you only sketch half the section profile so that when revolved it doesn’t intersect itself. All this and more is covered in the free training videos at learn.onshape.com
